RE: Anderson Power Pole Connectors. Have you had a failure or not?
I have had problems with APP connectors not making good contact. It seems that ( on assemling the connector) once you slide the metal connector into the plastic housing the connector must lock into the plastic part. If it does not lockin securely the two metal connedtion will make for a poor contact or no contact at all.
