RE: Kaos ARF initial setup
Thanks for all the info guys. It sounds like it'll at least make a successful first flight with a 0-0 setup with the thrust I have, so I'll try it and see. I set up the throws according to the manual except for no dual rate on the rudder which I split the difference between high and low. Any other setup suggestions would be appreciated. I want to get it right ASAP so I can start practicing maneuvers instead of working on my airplane.
