RCU Forums - View Single Post - Covering techniques
Old 08-02-2011 | 12:08 PM
SeamusG's Avatar
SeamusG
Default RE: Covering techniques
Gene - common problem - looking for a replacement myself ...
I call your strips "tack strips". Ultracote sticks better to Ultracote than it does to wood.
To conceal seams you can use the tip of your standard iron or the entire foot of a trim iron to "press" the bottom bit of film into the underlying wood. This will recess the bottom piece so that the top piece lays flat across the seam.
