ORIGINAL: jackstraw72
@ derek when you sayfilled with grease how much should be in there ?
You can fill with grease just about until it covers the gears not all the wayup tothe top. just gets messy when you put back together. If your bashing you may want to go with a marine grease better then auto bearing grease.
what type of surface are you going to be running on? have you pulled them apart yet?
