RE: Lost A Wheel in Mid air. How Do you Land?
After losing a wheel it was no more wheel collars for me! Now I epoxy brass tubing over the axle. The brass tubing has a washer soldered on the inboard end then goes the wheel and next another washer. A small hole drilled opposite end to insert a cotter pin which retains everything.
