RCU Forums - View Single Post - Silver Swallow Pulldown
Old 08-03-2011 | 02:53 AM
  #39
123Cat
Default RE: Silver Swallow Pulldown
Thanks for the conrod tip , Im doing a little machining when I can , I like the Silver Swallow its a good subject for a rebuild, boy the casting is bubbly and has cracks and faults when I cleaned it
crank 50% done
piston 50% done
Cylinder honed
rod
cant make up my mind whether to use a longer rod and space the cylinder upwards , ,,,, just dont know yet
By the way its a flight engine only , it will get half a tank run in maximum , so I will set it up on the loose side <br type="_moz" />
