RE: HTG struts mod for 90mm EDF's
If you are wondering about the "brakes', the paddle is pulled using fishing line. I use my flap servo to pull the line when retracting the flaps after landing. A separate servo could also be used buy with the flaps no extra channel is needed . When flaps extended brakes off, flaps up pulls the paddle and plane stops much faster....
