RE: How to make antennas
Small diameter spring wire from the K&S rack at your hobby store. If you need to you can solder the end. I use 600 grit paper, then solder it. I also put a short piece of yellow heat shrink tubing on the top end so I can see it. Pick a diameter that springs back the way you like. The thicker the wire the faster it will snap back to straight.
