RE: GP Extra 300S resurrection
From building the plane first time around I recall that the turledeck sheeting "sanded through" on more than one occasion. Withthe rebuild I have sheeted both the front and rear turtledecks with 3/32 sheeting and not the original 1/16. I think that works much better.
Now to install the servos and pushrods.
I have opted to go with the original design for the elevators with a single fuselage mounted servo with a pushrod for each elevator half. This means I need a trip to the LHS to get some pushrod material.....
I have reinstated the pull-pull from the original but have left the servo rails loose so that I can adjust the CG a little.
