RE: fUTABA sCREW dRIVER
Just use a screw driver from your toolbox. Stick tension adjustment is not something you do on the field and not very often. If you want it to clip to the TX handle use sone cotton string. Personally, my 9CAP is so heavy, I wouldnt like to add weight to it. In fact I have to use the neckstrap to prevent my elbows from shaking under its weight
Ameyam
