RE: Painting foam......Again need quick help
Krylon H2O spray paint is a latex paint that should be foam safe. However, it is still recommended that you test by spraying on a very small area first, just to be sure.
If you spray very light coats from a distance, you may find that other types of spray paint will also work. The key is to spray from a greater-than-normal distance to allow the volitile foam eating materials to dissipate into the air before hitting the foam.
Again: test, test, test on a very small area.
- Jeff
