RE: WALBRO Carburetors - Info for Dummies
Took my old chainsaw and weedeater out today...Not run since last year...Put fuel in and both cranked right up with no probem...The chainsaw and weedeater both had old fuel in the carb...
Run the fuel dry, or not...No problem either way....NO ethanol in Arizona gas....
The return spring is to return the chainsaw to idle when the trigger is released,and to keep the plate centered on the carb bore...Take it off and the plate and carb body will wear...Not right away, but it WILL wear both sides of the plate and the bore...You want to see some see some ??
