RE: New A7 from FEJ
Jim,
It sounds like you are saying that the gear mounts bolt to the former that is completely constructed with honeycomb core, is this true? If so, that is a very bad practice. In all applications where sandwich composite construction is used, the core MUST be replaced with a crush-proof material, like aircraft plywood, at every place where something is through-bolted to the structure. If this is not done, the strength of the structure is severely compromised.
Bob
