The elevator is now turned the right way, it still doesn't go up. If you hold it, it will pull but not enough to fly (the same as before I cracked it's nose
. The prop is on the right direction.<div>
</div><div>
</div><div>
</div><div>I'm not flying in a open street, the street leads to no where, the area is under construction. </div><div>
</div><div>Parks for flying are not an option, the nearest one is 1hr away.</div><div>
</div><div>
</div>
