just ordered this to go with it, my BEC is only 1.2a & im worried its not enuff for this servo & reciver
Dimensions: 45 x 27 x 10mm
Net Weight: 32g
Input Voltage: 4.8 - 20V
If input voltage is not higher than the selected output voltage, output voltage is equal to input voltage.
If input voltage is higher than the selected output voltage, output voltage is equal to the selected output voltage.
Output Voltage: 5V or 6V
Continuous Output Current: 5 Amps
Max Output Current: 7 Amps
Quiescent Current: 5mA
Cable Length: 110mm (Battery), 230mm (Receiver)
Features
1. Designed with an advanced switch mode DC-DC regulator IC, the max efficiency of the chip is 93%.
2. Large output current: a continuous output current up to 5A and burst output current up to 7A.
3. Electronic components are covered with a metal shield and a filter (ferrite ring) is attached to the output wires to significantly reduce the electromagnetic interference.
4. Output short-circuit protection function.
5. Input voltage range from 5v - 20v.
6. External switch to turn on or turn the output.
