After some playing around with linkages finally managed to come up with a system that keeps the servo arm and linkage on this below the wing surface so only the horn is visible, will need to double check the throws with Rich the designer and mastermind behind this little jet but having seen the v1 throws I think we should be good to go.
The servo covers on this version will have additional covers over the top to 'hide' the chipped servo hatch edges, something we hope to fully fix on the production kits.
There is provision through holes in formers to run the extension cables through to the front area of the wing route, the dashed lines show the cable route and the red the position of formers with holes for the run.
Flap servo and linkage, aileron servo and linkage shown for reference.
I am using a 10 way Ashlock connector for each wing, 6 wires for the two servos, 2 wires for the gear up/down and 2 wires for the brakes - no air lines to get in the way
Fuselage is out of the plug in an hour or so will post some work on this next.....
marcs
