ORIGINAL: M9cat
So I just bought some pusher props for my Super Cubs..I didnt know that they were counter rotating props so i just switched the red/blue wires from my motor to esc...How well or will the plane even fly right? It seems to be working just kinda scared to put into the air..
<p class="MsoNormal" style="margin: 0in 0in 0pt"><span style="font-family: Verdana; font-size: 7.5pt; mso-bidi-font-family: Arial">I am not 100% clear on your question but I will make a go at it.<o
></o
></span></p><p class="MsoNormal" style="margin: 0in 0in 0pt"><span style="font-family: Verdana; font-size: 7.5pt; mso-bidi-font-family: Arial">If I understand correctly, you have a front engine type airplane and you have purchased ‘pusher props’.<span style="mso-spacerun: yes"> </span>When you put the pusher props on your airplane and power up, the plane wants to got backwards – so you changed the motor to spin the opposite direction.<o
></o
></span></p><p class="MsoNormal" style="margin: 0in 0in 0pt"><span style="font-family: Verdana; font-size: 7.5pt; mso-bidi-font-family: Arial"><o
></o
></span></p><p class="MsoNormal" style="margin: 0in 0in 0pt"><span style="font-family: Verdana; font-size: 7.5pt; mso-bidi-font-family: Arial">Will this work?<span style="mso-spacerun: yes"> </span>Well…. Yes, sort of.<span style="mso-spacerun: yes"> </span>Is it recommended or a good idea?<span style="mso-spacerun: yes"> </span>NO.<span style="mso-spacerun: yes"> </span><o
></o
></o
></span></p><p class="MsoNormal" style="margin: 0in 0in 0pt"><span style="font-family: Verdana; font-size: 7.5pt; mso-bidi-font-family: Arial">The propeller ‘pusher prop’ you have is designed to be mounted on a rear engine plane where the propeller ‘pushes’ rather than ‘pulls’ the airplane along.<o
></o
></o
></span></p><p class="MsoNormal" style="margin: 0in 0in 0pt"><span style="font-family: Verdana; font-size: 7.5pt; mso-bidi-font-family: Arial">If you take a close look at the propeller you will see it is in-fact an airfoil – like a wing.<span style="mso-spacerun: yes"> </span>As the propeller spins it creates lift.<span style="mso-spacerun: yes"> </span>It is the lift (and some deflection) that causes the ‘pull’ force or thrust.<o
></o
></o
></span></p><p class="MsoNormal" style="margin: 0in 0in 0pt"><span style="font-family: Verdana; font-size: 7.5pt; mso-bidi-font-family: Arial">Again, taking a close look at the propeller you should see one side (the side away from the motor) has a slight curve (convex shape) and is thicker at the leading edge and thinner at the trailing edge.<span style="mso-spacerun: yes"> </span>The other side of the propeller is flat, or is some cases concave.<o
></o
></o
></span></p><p class="MsoNormal" style="margin: 0in 0in 0pt"><span style="font-family: Verdana; font-size: 7.5pt; mso-bidi-font-family: Arial">By spinning the propeller in the opposite direction you completely defeat the engineering that went into the design.<span style="mso-spacerun: yes"> </span>It is like putting your airplanes wing on upside down and with the trailing edge forward.<o
></o
></o
></span></p><p class="MsoNormal" style="margin: 0in 0in 0pt"><span style="font-family: Verdana; font-size: 7.5pt; mso-bidi-font-family: Arial">Because of the pitch in the propeller, it will deflect the air and produce thrust but it will not produce lift.<span style="mso-spacerun: yes"> </span>You will get substantially diminished performance and unpredictable behavior.<o
></o
></o
></span></p><p class="MsoNormal" style="margin: 0in 0in 0pt"><span style="font-family: Verdana; font-size: 7.5pt; mso-bidi-font-family: Arial">In addition to the diminished performance, you will be introducing stress and loading to the propeller that was never intended.<span style="mso-spacerun: yes"> </span>The propeller may tolerate the stress or it may fail.<span style="mso-spacerun: yes"> </span>If the propeller fails when someone is in the path of the debris the results could be disastrous.<o
></o
></o
></span></p><p class="MsoNormal" style="margin: 0in 0in 0pt"><span style="font-family: Verdana; font-size: 7.5pt; mso-bidi-font-family: Arial">If the propeller is designed to push, let it push – don’t make it pull.<span style="mso-spacerun: yes">
</span></span></p>
