RE: Just ordered a MoJo .60
Sotos,
The reason I am considering the ST is that It is the engine that I have. I also have a OS 7M and 7D carb laying around not doing any thing. I will be using one of these two carbs on my ST to get the midrange to run and transition properly.
mrbigg,
I actually have not run the combo yet but will post back some re****s once I do. I am hoping to run a 15 or 16x4 prop around 10 to 11 thousand RPM. I post what I find out on this setup.
Anyone,
I am currently building the Mojo 60 with the removable wing. The two small rectangular blocks with the three holes in them that are for the landing gear do the get glued into the fuse before it is laminated on both sided with the plywood? Or does that rectangular hole on the fuse stay hollow when it is laminated with the ply? Thanks much.
