RE: EVSD-5U-EVO multifunction valve
Okay got you, if it was working then you can narrow it down to leaking cylinders or bad valve. You might want to pinch off the cylinder lines to make 100% sure it's not a cylinder causing your problem. I know a lot of people have had trouble with the valves only to find out it was cylinder causing the problem. I'm not saying that's your problem, just make sure it isn't.
Hope you get it sorted out.
