Hi Jack,
NO BOTHER AT ALL
I want to help, if I can!
Well, your idea about shortening the adjusting screws certainly makes sense, but now that my linkage and everything is all set for where my Moki is mounted, I am thinking the easiest fix is to extend the prop shaft perhaps a cm or two; I have not yet calculated the scale distance.
The THOR ignition driver is a device made by 42% Products. It eliminates the extra ignition battery, extra switch, and engine kill... the THOR does it all using your on-board radio batteries. You simply plug it into any unused channel (On/OFF switch channel) and it provides power to the ignition module while also functioning as a Kill switch. It only goes on when your radio goes on.
I use these in ALL my gas planes and cannot understand why anyone would not!![X(]
Simpler, lighter, more reliable.
http://42-percent-products.com/home.html
