RCU Forums - View Single Post - Aerofly Pro - New Models - Loading Probs
Old 08-22-2003 | 06:53 PM
UKflyer
Default Aerofly Pro - New Models - Loading Probs
Hi Ian / Mike
I think I know why you are having probs with the Raven ......
The ZIP file is called Raven_ma.zip, this holds a separate folder called Raven, which in turn holds the 5 files ...... note that the 5 files are called Raven.*** and NOT Raven_ma.***
Make sure the aircraft directory in this case is called Raven.
DITCHIT ..... The Twinjet is similar .... the aircraft file has to be AS_Twinjet, not AS_Twinjet_upd, and don't forget to put the Twinjet.wav file in the sound directory.
Bob is most definately your Father's brother!! ...... ENJOY
Dave
