You could do a Pmix with Throttle as the Master and Elevator as Slave and then set your rates to a small amount, adjustments to the amount of rates will probably take a couple times to get this correct, but it isn't too hard.
First go into an empty Pmix, press the cursor button to enter the mix, press the Down key twice. You will INH flashing, cursor over, press the cursor button and change this to Off. Press the down button once, and set Master as CH3, press Down once more and set the Slave as CH2. At the very bottom you will see the switch selection, if you would like this mix to be active only occasionally, then set this to the switch of your preference. If you would like this to be active continually, then set the switch to Null ().
Pressing the down arrow button once more, you will be on the Rate page, I would set these rates fairly low to begin with, once you fly, you will be able to decide if you need to add more or less elevator per the throttle action.
Sincerely,
Krysta
Product Development & Support Specialist
Futaba Service Center USA
[email protected]
