RE: Savage half tank EXTREME lean problem.
Ive been told for thirty years that heat changes tolerance meaures and causes weakening of metals and uneven wear. if thats off then why does my car need fluid to heck with coolant its too expensive. are you saying an rc engine will run at 600 degrees with no failure?
The double tank method is unbeatable. Its the best way for sure.
