ORIGINAL: brandon429
Ive been told for thirty years that heat changes tolerance meaures and causes weakening of metals and uneven wear. if thats off then why does my car need fluid to heck with coolant its too expensive. are you saying an rc engine will run at 600 degrees with no failure?
The double tank method is unbeatable. Its the best way for sure.
The difference between running 320 degrees and 290 degrees is going to be negligible. Do you want him to rush out and buy a new engine just because he had a little high temperature spike? Jeez
320 degrees is not enough to hurt anything inside the engine. Period. Prove ThunderbirdJunkie wrong. With science, not a bunch of horsecrap spouted by "experts".
