RCU Forums - View Single Post - Thinking about my first plane
Old 08-18-2003 | 07:08 PM
Rick Lindsey
Default Thinking about my first plane
Be sure you trace all the bits and pieces that aren't shown explicitly on the plans if you want to build another when you're done! I'm pretty sure my LT-25 plan doesn't show what all the pieces look like, since they are all pre-cut for you.
I'm planning to do the same thing except it's because I want to learn fly with the stock wing, but then play around with flaps once I'm starting to get the hang of this flying thing .
If you get a used engine, then I suspect you can stay under $400 without too much trouble, especially if you already have some of the building supplies. I'm sure all the odds and ends end up costing a bundle, but just looking at the major items... $70 for a kit (my LT-25 was $67 at tower hobbies), $130 for a 4-channel radio with 4 servos, even a new OS 25LA or magnum xl-25 is only about $60 (and shoot, the 40LA looks to be the same price as the 25LA if you are a member of the "more power!! HARHARHAR" camp). That should leave over $200 of your initial $400 for other bits and accessories... I priced out a full set of building materials from tower once (one of each CA, one of each epoxy, the fancy aluminum sanding blocks and a bunch of several grits of sticky-back sandpaper, razor saw, xacto knife etc.) and it was ~$100
That leaves another $100 for flightline supplies.
I think if you're careful, you should be able to come in under $400 easily.
-Rick
