ORIGINAL: Mudball3
zacharyR
I am running a Futaba R6014HS 14-Channel 2.4GHz FASST Receiver. I looked it up on futabas website and I dont see the current rating listed. Just the input voltage. Is there and advantage over one of those two power systems?
well not relaly a advantage simple'st set up with be, Duralite A123's set up , second would be Lion's you'd need to have two regulator's on that set up .. 3rd would be a smart fly ,, you would use Lion's with the smart fly
not sure on your inginition . but some name brand's do not like over 6 volt's so you have to use a regulaor or a IBEC on A123'S / LiFe 's
it's a personal choice and a budget choice . if it was my airplane I'd run the A123's with internail balancer's and call it a day ...
and that's a newerr RX it can handle the power .....
