RCU Forums - View Single Post - AR9000 versus AR8000
Old 08-10-2011 | 03:46 PM
Rob2160's Avatar
Rob2160
Default RE: AR9000 versus AR8000
ORIGINAL: ntsmith
Interesting. Using the JR11X so after seeing the video I shant bother with the AR9000 and go with the AR8000
thanks everyone
Of all the radios i have range tested (quite a few different ones) the 11X has the best overall range.
once you install the AR8000 in your aircraft I still recommend doing a "walk range" test..
I never rely on the Power down range check.... I have been in hobby for 34 years and have seen enough aircraft crash (not mine) due to loss of radio contact at a distance.. which ended up being a loose aerial in the TX....
So I fully range check every new radio / rx and installation..
Never had a loss of control in flight.. and I did find one faulty Spektrum clone receiver by doing this.. it only range checked to 150 meters... so I never used it..
