RE: Quick Question.
If you read the fine print it says to avoid setting objects onto the paint for two weeks after application as it can still stick with enough pressure. I have waited a full month and had a finish that has lasted with no adverse effects to four stroke exhaust, and I did fly a cowl after 3 days and had some issues. The longer the better. I also found the metallic paints are not at all resistant even to exhaust.
