RE: Skymaster Mig29 with P200
Ok, time for a quick update. I have been focusing on doing the equipment install lately. I am waiting on some shrink wrap currently but have gotten some things done. I drew up some mounts for the ECU and UAT in Vectric and cut them out on the CNC machine with a new roughing bit I got from McMaster. Man it cuts that G10 great!! I also drew up a fuel pump mount and glued it together and seems to fit just perfect.
The ECU mount is just a plate of G10 that has been shrunk wrapped to the ECU using some battery shrink wrap and it holds it solid. This will be bolted to one of the floors I put in the nose section. The UAT will be mounted the same way but with a little different way of securing it to the board and I will go into detail more on that when I am ready to mount it.
I also got the small fuel tank mounted with some industrial velcro which should hold it solid even when full. I had to add a little "floor" to hold it though, just epoxied some ply to the top of the turtldeck above the nose wheel when retracted.
