RCU Forums - View Single Post - .60 size Pattern Tiporare Build
Old 08-12-2011 | 01:36 PM
  #175
doxilia's Avatar
doxilia
Default RE: .60 size Pattern Tiporare Build
Thought you might also like to see where I started with the wing center section. Although it felt smooth and continuous to the touch, it required plenty of prep work prior to the final coat of primer. It now looks like a single continuous smooth area so I'm a happy camper. White is done. Flash for 48 hrs. I'll post some pics once I've got the red on the underside.
Last pic is LK Missile Red test - no where close to MK. It's more orange than red. Will have to substitute for better match.
David.
ID:	1648043   Click image for larger version
ID:	1648044   Click image for larger version
ID:	1648045   Click image for larger version
