ORIGINAL: Edwin
I use this on my G62's. 18v milwakee battery drill. Works! I make my living with my hands. Had a close call last year. Minor incedent but could have been real bad.
Edwin
Great Idea.
My procedure without a starter is as follows.
-Choke on
-full throttle (it will not run away with full choke)
-prop till it fires
-choke off
-throttle to idle
-prop again till it starts (usually only 3 or 4 times.
This is a tried and proven method and works every time unless you have a problem with fuel or ignition
I also ALWAYS use a heavy glove to hand prop.
