RE: help
Bigger diameter, smaller pitch. That will slow down your model on landing, but will also reduce your top speed. If you don't want to reduce the top end, practice slowing it down at altitude. If you can get it to descend at idle just above stall then you can slow it for landing, and you just need more practice on that plane. If it just cruzes around at idle not descending then your only good option is to change the prop.
