RE: Savage half tank EXTREME lean problem.
There's a clunk on the end of some fuel line inside that airplane tank. Mounted horizontally, as it would be in an aircraft of some sort, this clunk will stay in the fuel when the truck flips over, allowing the engine to draw from the header tank while you walk over to it and flip it back over. Aircraft need this because they fly inverted and require fuel flow while doing so.
