RE: Antenna wire length - does it matter
Again, thank you for the help. Icertainly appreicate it.
You mention the RX 'binding' with the TX upon powering up both RX and TX. Iget it, but here's my question:Can Ibind one radio to two RX units? Ihave an eSky Honey Bee FPand an eSky Honey Bee V2 FP - both share what looks to be exactly the same 4 in 1.
I'm sure this is possible, seeing as you can buy the 4 in 1 separate from a controller.
It looks like there is a tiny switch on the 4 in 1, but it's function is not documented. Isuspect that it is used for the 'binding' process to a controller.
Oh, and could someone give me the correct terminology for what Ithink of as the controller?Ihave heard it called the "TX", the "Radio", and the "Controller".
Thanks in advance.
Cake
