RCU Forums - View Single Post - CDI gr8flyer55
Old 08-13-2011 | 10:58 PM
nyemi
Default RE: CDI gr8flyer55
Hi Fly42
<span lang="en" id="result_box"><span class="hps">I have seen</span> <span class="hps">many</span> <span class="hps">ignition</span> <span class="hps">curve.</span>
<span class="hps">2T</span><span>-4T</span> <span class="hps">much difference</span><span>.</span> <span class="hps">I will show</span> <span class="hps">RCexl</span> <span class="hps">original</span> <span class="hps">ignition</span> <span class="hps">curve.</span> <span class="hps">This is</span> <span class="hps">a general</span> <span class="hps">curve</span> <span class="hps">which is not good</span> <span class="hps">2T</span><span>-4T</span><span>.</span> <span class="hps">2T</span> <span class="hps">much</span> <span class="hps">ignition advance</span><span>.</span> <span class="hps">4T</span> <span class="hps">little</span> <span class="hps">ignition advance</span><span>.</span></span><span lang="en" id="result_box"><span class="hps"> The problem</span> <span class="hps">can be corrected by</span> <span class="hps">the Hall</span> <span class="hps">position.</span> <span class="hps">More or</span> <span class="hps">less success.</span></span><span lang="en" id="result_box">
<span class="hps">I</span> <span class="hps">show</span> <span class="hps">Walbro</span> <span class="hps">ignition</span> <span class="hps">curve</span> <span class="hps">supply.</span> <span class="hps">I have</span> <span class="hps">created</span><span>.</span> <span class="hps">Walbro</span> <span class="hps">ignition</span> <span class="hps">curves</span><span>, hex</span> <span class="hps">program.</span>
<span class="hps">Will soon</span> <span class="hps">be in touch.</span></span>
File Type: pdf
