RCU Forums - View Single Post - Servo Chatter
Old 08-14-2011 | 04:41 AM
chemie's Avatar
chemie
Default RE: Servo Chatter
Actually, Brad, the reason I got worried was that the plane had a bad wiggle in the air like the rudder was being pushed around. It did that once before when the same servo had two front screws come out and I thought it was that. I am actually surprised the jiggle is enough to cause the wiggle ;-)
This is a Futaba 3305..can cleaning the pot correct this? Could having too high tension on the pull-pull have caused this?
After pulling off the case, then what?
