RE: Minor Glitching on Heli - Any Ideas?
Check your wireing from the motor to the esc. On my old XL motor on my 450 wires would seem to work loose in the motor after a fair number of flights. also CK your solder connections on the motor & esc. could of had a cold solder joint that going bad & causing intermittent loss of power. If its that it becomes a real isue when you lose power and have no contol. Heli becomes a lawn dart [&o]
