RCU Forums - View Single Post - What is the function of crow?
Old 08-14-2011 | 10:30 AM
  #53
highhorse's Avatar
highhorse
Default RE: What is the function of crow?
ORIGINAL: RCJetBazz
ORIGINAL: highhorse
For the persistent but aerodynamically challenged:
Flexing an aileron upwards makes ''lift in a downward direction'' along that portion of the wing, and that's half of what banks your airplane (The other aileron moving downward and increasing lift on that side is the other half). With us so far? Good.
Flexing BOTH ailerons up makes ''lift in a downward direction'' along the portion where the ailerons are located on both wings simultaneously. Still with us? You sure? Great, you're almost there, so hang on.
With both ailerons flexed up part of each wing dedicated toward making ''downward lift'', and there is less wing on each side still making ''upward lift''.
There is no way, none, that an aircraft in this configuration has a lower stall speed. That. Is. Physically. Impossible. It may indeed be flying more slowly than without the reflexed ailerons simply because of the extra drag, but the stall speed is higher. Not lower. Period.
Sorry, I'm not picking on anyone. I promise. The physics just is what they is.
If I learned anything from the now infamous ''Downwind Turn Myth'' thread though, it's that some will deny the truth at all costs rather than even contemplate the possibility that they have been operating under false impressions or assumptions. Them folks just is what they is too, so God bless 'em!
Your understanding of aerodynamics/physics seems partial, it has everything to do with the location of different config, spanwise.
Why is washout so important on modern airplane (with reflexed airfoil, ((only towards the outboard span of the wing with a negative incident)) ? A: to improve low speed handing
Perhaps you could use a electic foamy and increase lift (incident) on the outboard only, to find out it will do nothing but to snap into uncontrollable spins like crazy at low airspeed
My comprehension of aerodynamics is actually very good, thanks. What's lacking is your perception that the above description was meant to be anything other than farcically partial.
Thanks for playing though.
