RE: Aileron differental
It is best to add weight to the tip as it will minimize the amount needed. I am sure there is a good way, but I have always just used trial and error with stick on weights. After you determine how much you need you can then affix them permanently. On solid tips I just drilled a hole and epoxied them in the hole filled it and patched it. Just make sure it is solidly affixed to the wood frame.
