RE: Doping a frame
I dope all balsa areas to harden it up - helps prevent denting. The dope does not add that much weight; most of the weight is the volatiles that evaporate. If you use Stix-it, or some other adhesive, you only put it on the perimeters you are covering. I am sure you know this allready. Very nice looking craft.
