RE: RCGF Engines
Hey "G",
Also remember that this will not run like one of your Alki moters. These gassers are more about torq and not so much RPM. Your little engine tops should run around 7200 rpm tops on the ground. If it is much higher than that you might want to look at your prop. Just some food for thought.
Captmicom[8D]
