ORIGINAL: hyflyer9
ORIGINAL: goirish
ORIGINAL: hyflyer9
ORIGINAL: goirish
I will put the plane on the stand and run it tomorrow and post some numbers. What do you think would be a good prop size. I'm using a K'Series MAS 16/8
Hi goirish
I am using an XOAR 18x8 Beach prop and am getting very good results at 7100-7300 RPM with lots of thrust and a very good transition
is that for the 26 size?
Ye the RCGF 26cc engine
after the first 3 or 4 tanks of gas run threw it I changed over to an XOAR 18x8
what size did you start out with?
