RCU Forums - View Single Post - which do you prefer tail dragger or a trike style
Old 08-16-2011 | 07:49 PM
D.L.R.
Default RE: which do you prefer tail dragger or a trike style
Tail dragger all the way. With 3+ inch wide foam wheels you can take off and land on almost ANYTHING within reason. I've seen comments about breaking props more often, but if the gear is properly placed and the "engine down thrust" is not excessive, DOWN elevator or a gopher hole are about the only way you could stick a prop in the ground.
Dan
