I have around 15 flights with mine. Powered by a DLE 30, using now a Xoar 19x8. The best performance obtained with a Graupner G Sonic 20x8. That's why I will try to use bigger wheels and to install 2 springs between the left axle and the far right allen screw that holds the right half of the landing gear on the fuse and vice versa, in order to get more ground clearence. Very good quality ARF. I hope the quality will be confirmed in my next project, Decathlon 120 from Seagull.
Lost both pilots during an inverted flight
sometimes
double-sided tape is not enough.
