Range Check
Although not mentioned in the manual that comes w/ the radio, I realize some of us will range check our 72MHz planes by lowering the Tx antenna and checking from a short distance on the ground. Question is: Generally speaking, at what distance would you expect everything to continue to work properly w/ the Tx antenna down? Thanks.
