RE: JR DSM question
yes it can be done where you could put your brake on a slider or switch that you could activate after separation..
DSM2's are bound at the same time because the receiver accepts the GUID, which is generated at startup when the bind button is pressed.
I dont know on DSMX , as the two way interaction may require separate binding sequence since the transmitter is listening for a ping from the receiver during bind.
