RCU Forums - View Single Post - 2 Stroke V. 4 Stroke
Old 08-17-2011 | 08:04 AM
Gray Beard
My Feedback: (-1)
Default RE: 2 Stroke V. 4 Stroke
Neither of the engines know they are inverted, they both will run well but you do need to make sure your fuel tank is mounted a little lower or you will get flooding and vapor lock sometimes. Just minor things. The four stroke tends to have fewer problems when inverted. An old trick is to mount the engine at a slight angle and not straight down. Just a little trick, mine are mounted straight down but I have been doing this for a little while.
