ORIGINAL: vertical grimmace
After spending quite a bit of time with my 30 tonight, I could not get it to work. I am going to try another ignition to see whats up, and most likely will send it back to Valley view to have it looked at. I am beginning to think it is ignition related.
By the way, is there another option for a plug cap? Are the RCxcel caps different than the stock DLE ignition caps? It seems that the little coil wire inside these caps is so fragile, I am not confident it is making good contact all the time.
Look for black soot on the plug cap, shows a bad connection and arching. Have you checked the timing?
