RCU Forums - View Single Post - DLE 20cc Gasser! (Data & Links 1st Post)
Old 08-17-2011 | 10:25 PM
  #4336
Ernie Misner's Avatar
Ernie Misner
Default RE: NEW DLE 20cc Gasser! (Data & Links 1st Post)
Doug, on your 7C with digital trims that are accurate and repeatable, just give it two (or whatever is needed) clilcks of down trim on the throttle trim before landing and then click it back up the same amount before taking off again. (if indeed you do have a problem with the throttle curve once you get it going).
Ernie Misner
