RE: RCGF Engines
I discovered that a 6mm bolt would require drilling the spinner hole out. I do not feel it has enough room so I need to use 5mm bolt. Because I have not been able to find a 5mmx.8x110 I decided to make my own. I used a 90mm and a 25mm bolt and sodered them together to get the proper length. I taped a section of brass tubing screwed the bolt in from each end then sodered them. Because the bolt is used to only hold on the cone I think it will be strong enough. Any ideas out there?
Have a good day, P51Tom
